Ana içeriğe geç
Samsung Alias 2 Hinge Replacement
Neye ihtiyacın var
  1. Samsung Alias 2 Hinge Replacement, Battery: adım 1, 1 resimden 1.
    • Press down on the back cover of the phone and remove it.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Alias 2 Hinge Replacement: adım 2, 1 resimden 1.
    • Take out the battery from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Alias 2 Hinge Replacement, Hinge: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 4 mm screws on screen.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Alias 2 Hinge Replacement: adım 4, 2 resimden 1. Samsung Alias 2 Hinge Replacement: adım 4, 2 resimden 2.
    • Use the opening tool to remove the front outside casing.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Alias 2 Hinge Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove ribbon connector next to camera using tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Alias 2 Hinge Replacement: adım 6, 1 resimden 1.
    • Unscrew and remove the two 3.95 mm screws underneath that ribbon connector.
    • Be careful not to lose their accompanying plastic washers.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Alias 2 Hinge Replacement: adım 7, 2 resimden 1. Samsung Alias 2 Hinge Replacement: adım 7, 2 resimden 2.
    • Pull the two halves of the phone apart.
    • The phone will not slide straight apart. You have to angle the back half up a little.
    • Do not force it. Jiggle it a little if it doesn't come apart.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Alias 2 Hinge Replacement: adım 8, 1 resimden 1.
    • Remove the plastic panel cover from the hinge.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Alias 2 Hinge Replacement: adım 9, 2 resimden 1. Samsung Alias 2 Hinge Replacement: adım 9, 2 resimden 2.
    • Remove the 3.41 mm screw out from underneath plastic cover.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Alias 2 Hinge Replacement: adım 10, 2 resimden 1. Samsung Alias 2 Hinge Replacement: adım 10, 2 resimden 2.
    • Pop out the top half of the hinge with the plastic opening tool. This will release the hinge cover for removal.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Alias 2 Hinge Replacement: adım 11, 2 resimden 1. Samsung Alias 2 Hinge Replacement: adım 11, 2 resimden 2.
    • Pull off the hinge cover.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Alias 2 Hinge Replacement: adım 12, 2 resimden 1. Samsung Alias 2 Hinge Replacement: adım 12, 2 resimden 2.
    • Remove the two 2.71 mm screws on the hinge using screwdriver.
    • Under these screws will be a washer, spring, and small metal disc. Make sure you don't lose these.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Alias 2 Hinge Replacement: adım 13, 1 resimden 1.
    • Remove the Verizon logo from the back of phone using the plastic opening tool.
    • The logo is attached with glue. It will be sticky, but it just pulls off.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Alias 2 Hinge Replacement: adım 14, 1 resimden 1.
    • Remove the four 4.44 mm screws from the back.
    • Remove the three 4.35mm screws from under the Verizon logo.
    • Make sure you don't mix the screws together.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Alias 2 Hinge Replacement: adım 15, 1 resimden 1.
    • Pull the back off by using the plastic opening tool.
    • Do not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
    FixBot'a Sor
    Yorum Ekle
  16. Samsung Alias 2 Hinge Replacement: adım 16, 1 resimden 1.
    • Pull up on the yellow tab.
    FixBot'a Sor
    Yorum Ekle
  17. Samsung Alias 2 Hinge Replacement: adım 17, 1 resimden 1.
    • Disconnect the connecting cord using tweezers.
    FixBot'a Sor
    Yorum Ekle
  18. Samsung Alias 2 Hinge Replacement: adım 18, 1 resimden 1.
    • Disconnect the rectangular ribbon.
    FixBot'a Sor
    Yorum Ekle
  19. Samsung Alias 2 Hinge Replacement: adım 19, 1 resimden 1.
    • Remove the logic board.
    FixBot'a Sor
    Yorum Ekle
  20. Samsung Alias 2 Hinge Replacement: adım 20, 1 resimden 1.
    • Remove the three 3.95 mm screws.
    • The two rightmost screws must be pulled out with tweezers after unscrewed.
    FixBot'a Sor
    Yorum Ekle
  21. Samsung Alias 2 Hinge Replacement: adım 21, 1 resimden 1.
    • Pull the hinge out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris
133 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G35
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 4,678
