Giriş
This guide tells you how to remove a faulty logic board and install a new one.
  1. push down the back cover of the phone, then take it out.
    • push down the back cover of the phone, then take it out.
  2. Remove the battery.
    • Remove the battery.
    • Remove the (4) 4.2 mm screws from the four corners of the battery slot.
    • Use plastic opening tools to peel off plastic Verizon logo tab from the top of the back outside.
    • Note: The tab is stuck on there with glue, this is alright, just peel it off.
    • Remove the (3) newly uncovered 4.3 mm screws.
    • Remove the back outside casing using the plastic opening tool.
    • Warning: Do Not lose the buttons on the side of the phone, as they will come off of the phone when you remove the back outside casing.
    • Pull up on the yellow tab.
    • Disconnect connecting cord using tweezers.
    • Disconnect rectangular ribbon.
    • Remove logic board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris
133 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G35
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 9
Her zaman: 2,502
