Ana içeriğe geç
Samsung Alias 2 Speaker Replacement
Neye ihtiyacın var
  1. Samsung Alias 2 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Push down on the back cover of the phone, then remove the back cover.
  2. Samsung Alias 2 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. Samsung Alias 2 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove the two (4.1 mm) screws down the screen.
  4. Samsung Alias 2 Speaker Replacement: adım 4, 2 resimden 1. Samsung Alias 2 Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the upper casing with a plastic opening tools.
  5. Samsung Alias 2 Speaker Replacement: adım 5, 1 resimden 1.
    • Use soldering iron to melt, and remove soldering joints of the speaker.
  6. Samsung Alias 2 Speaker Replacement: adım 6, 2 resimden 1. Samsung Alias 2 Speaker Replacement: adım 6, 2 resimden 2.
    • Use tweezers to remove the speaker from its place.
    • Note: There are two speakers. Make sure you know which one is broken before removing it.
  7. Samsung Alias 2 Speaker Replacement: adım 7, 2 resimden 1. Samsung Alias 2 Speaker Replacement: adım 7, 2 resimden 2.
    • Use tweezers to insert the new speaker into the speaker slot.
  8. Samsung Alias 2 Speaker Replacement: adım 8, 1 resimden 1.
    • Solder a speaker ribbon to the logic board.
    • Note: be careful to match the right polarity before you solder.
Sonuç
Chris
133 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-35, Maness Spring 2011 Cal Poly, Team 12-35, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G35
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 2,094
