Neye ihtiyacın var
To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
I had trouble putting the vent side back in, it didn’t fit correcly. If it wasn’t late I would of done a proper disassemble. Plus it’s not a full one where it shows taking off the side panels and the front panel to access the touch screen.
if you are having issues with the model shutting off and on, you don’t have to remove the front panel you can get access to the gray plug after you take off all the top and side panels.
