Ana içeriğe geç
Samsung BD-D5500 Disc Tray Replacement
Neye ihtiyacın var
  1. Samsung BD-D5500 Disc Tray Replacement, Samsung BD-D5500 Disassembly: adım 1, 1 resimden 1.
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Tray Replacement: adım 2, 2 resimden 1. Samsung BD-D5500 Disc Tray Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Tray Replacement, Disc Tray: adım 3, 1 resimden 1.
    • To remove the disc hub all you have to do is remove the 4 screws holding it down.
  4. Samsung BD-D5500 Disc Tray Replacement: adım 4, 1 resimden 1.
    • To replace the disc tray open the disk hub and unsnap the sides of the device.
  5. Samsung BD-D5500 Disc Tray Replacement: adım 5, 1 resimden 1.
    • Locate the slider that reads open and close.
    • To open the disc tray slide it to the side that says open.
  6. Samsung BD-D5500 Disc Tray Replacement: adım 6, 1 resimden 1.
    • Return it face up and the disc tray will slide out.
Sonuç
Brandon Nelson
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 1,010
