Ana içeriğe geç
Samsung BD-D5500 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung BD-D5500 Motherboard Replacement, Samsung BD-D5500 Disassembly: adım 1, 1 resimden 1.
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Motherboard Replacement: adım 2, 2 resimden 1. Samsung BD-D5500 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Locate the motherboard within the red rectangle.
    • Locate the power supply within the orange rectangle.
  4. Samsung BD-D5500 Motherboard Replacement: adım 4, 1 resimden 1.
    • The screws securing the motherboard in are labeled with red circles and the wires are labeled with orange rectangles.
    • Use your screwdriver with a PH2 sized head and unscrew these 1.2mm screws labeled with red circles.
    • Detach the wires connected the motherboard from the disc drive that are labeled in orange.
  5. Samsung BD-D5500 Motherboard Replacement: adım 5, 2 resimden 1. Samsung BD-D5500 Motherboard Replacement: adım 5, 2 resimden 2.
    • Labeled with a red rectangle is the location where they are connected. Grab the motherboard in one hand and the power supply in the other, and pull the motherboard up and push the power supply down. The motherboard and power supply should then disconnect.
Sonuç
Trevor Neman
284 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 610
