Giriş
This guide details the process of replacing the player's power supply module. The power supply is mainly responsible for powering on the device so this may answer many problems concerning this issue.
Neye ihtiyacın var
To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
Unscrew the 1.2mm screws labeled with a red circle and remove the power supply from the player.
