Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the three 10mm screws with a Phillips #0 screwdriver.
Pry the top off with a plastic opening tool.
Remove the three screws holding down the cover with a Phillips #0 screwdriver.
Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
Remove the 7mm screw with a Phillips #1 screwdriver.
Grip the blue tab attached to the base and pull upwards.
Grip the edges of the motherboard and pull upwards to remove.
