Ana içeriğe geç
Samsung BD-F5700 Disc Reader Replacement
Neye ihtiyacın var
  1. Samsung BD-F5700 Disc Reader Replacement, Power Cord: adım 1, 3 resimden 1. Samsung BD-F5700 Disc Reader Replacement, Power Cord: adım 1, 3 resimden 2. Samsung BD-F5700 Disc Reader Replacement, Power Cord: adım 1, 3 resimden 3.
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Disc Reader Replacement: adım 2, 3 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 2, 3 resimden 2. Samsung BD-F5700 Disc Reader Replacement: adım 2, 3 resimden 3.
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Disc Reader Replacement: adım 3, 2 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 3, 2 resimden 2.
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Disc Reader Replacement: adım 4, 1 resimden 1.
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
  5. Samsung BD-F5700 Disc Reader Replacement, Disc Reader: adım 5, 3 resimden 1. Samsung BD-F5700 Disc Reader Replacement, Disc Reader: adım 5, 3 resimden 2. Samsung BD-F5700 Disc Reader Replacement, Disc Reader: adım 5, 3 resimden 3.
    • Firmly grip the hard plastic tab attached to the base and pull upwards.
    • It is important to not tear the ribbon cables.
  6. Samsung BD-F5700 Disc Reader Replacement: adım 6, 2 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 6, 2 resimden 2.
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  7. Samsung BD-F5700 Disc Reader Replacement: adım 7, 3 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 7, 3 resimden 2. Samsung BD-F5700 Disc Reader Replacement: adım 7, 3 resimden 3.
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
  8. Samsung BD-F5700 Disc Reader Replacement: adım 8, 3 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 8, 3 resimden 2. Samsung BD-F5700 Disc Reader Replacement: adım 8, 3 resimden 3.
    • Flip up the black locking tab on the ZIF connector.
  9. Samsung BD-F5700 Disc Reader Replacement: adım 9, 3 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 9, 3 resimden 2. Samsung BD-F5700 Disc Reader Replacement: adım 9, 3 resimden 3.
    • Remove the 10 mm screw using a Phillips #1 screwdriver.
    • Remove the small metal bar by pulling it outwards.
  10. Samsung BD-F5700 Disc Reader Replacement: adım 10, 2 resimden 1. Samsung BD-F5700 Disc Reader Replacement: adım 10, 2 resimden 2.
    • Flip the disc tray over so the laser points downward.
    • Pull the disc reader out of the disc tray.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Livan Perez
303 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 638
