Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will show you how to open up the device to remove and replace the disc tray.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the two 10mm screws with a Phillips #1 screwdriver. Use the plastic prying tool to separate the top plastic casing from the bottom metal casing.
    • Remove the two 10mm screws with a Phillips #1 screwdriver.
    • Use the plastic prying tool to separate the top plastic casing from the bottom metal casing.
  2. Grip the blue tab and pull upwards to remove the ribbon cable from the motherboard. If it feels stuck, wiggle it while pulling gently to coerce it out. If it feels stuck, wiggle it while pulling gently to coerce it out.
    • Grip the blue tab and pull upwards to remove the ribbon cable from the motherboard.
    • If it feels stuck, wiggle it while pulling gently to coerce it out.
  3. Remove  the two 7mm screws with a Phillips #1 screwdriver.
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  4. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
    • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
Sonuç
Livan Perez
285 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 177
