Ana içeriğe geç
Samsung BD-F5700 Power Cord Replacement
Neye ihtiyacın var
  1. Samsung BD-F5700 Power Cord Replacement, Power Cord: adım 1, 3 resimden 1. Samsung BD-F5700 Power Cord Replacement, Power Cord: adım 1, 3 resimden 2. Samsung BD-F5700 Power Cord Replacement, Power Cord: adım 1, 3 resimden 3.
    • Use Phillips 0 Screwdriver to remove two (2), 10 mm rear screws.
    • Use the iFixit opening tool to help separate the top plastic casing from the bottom metal casing.
    • When opening the device, be careful to not damage the ribbon cable circled in image 3.
  2. Samsung BD-F5700 Power Cord Replacement: adım 2, 3 resimden 1. Samsung BD-F5700 Power Cord Replacement: adım 2, 3 resimden 2. Samsung BD-F5700 Power Cord Replacement: adım 2, 3 resimden 3.
    • Use Phillips 0 screwdriver to remove two (2), 10 mm screws from the plastic cover.
    • Remove plastic cover from board.
  3. Samsung BD-F5700 Power Cord Replacement: adım 3, 2 resimden 1. Samsung BD-F5700 Power Cord Replacement: adım 3, 2 resimden 2.
    • Pull upward on back of the black and white wire to dislocate the black tab piece from device.
    • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  4. Samsung BD-F5700 Power Cord Replacement: adım 4, 1 resimden 1.
    • Insert the iFixit Opening tool into the black tab on the power cord, and use leverage to open the black tab.
    • Pull the tab off the wire so that it can be placed on the replacement cord.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Straits
236 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G4, Boczar Spring 2018 USF Tampa, Team S16-G4, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S16G4
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 269
