Giriş
If you ever have a need access any of the components inside the device, the first thing you have to do is remove the top cover. If you follow these easy steps, you should have no problem.
Neye ihtiyacın var
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
Tilt the back of the top cover forward to remove from chassis.
Neredeyse bitti!
Sonuç
