Ana içeriğe geç
Samsung BD-F7500 Blu-ray Player Disc Tray Replacement
Neye ihtiyacın var
  1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: adım 1, 2 resimden 1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement, Disc Tray: adım 1, 2 resimden 2.
    • Use a Phillips head #J1 screwdriver to remove all three (3) 10 mm screws.
  2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 2, 3 resimden 1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 2, 3 resimden 2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 2, 3 resimden 3.
    • To remove each ribbon cable, firmly grip the hard plastic tab attached to the base and pull upwards.
    • Be careful not to tear the ribbon cables.
  3. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 3, 3 resimden 1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 3, 3 resimden 2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 3, 3 resimden 3.
    • Using a screwdriver with a #J1 bit, remove the two (2) 7 mm screws.
  4. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 4, 3 resimden 1. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 4, 3 resimden 2. Samsung BD-F7500 Blu-ray Player Disc Tray Replacement: adım 4, 3 resimden 3.
    • Locate the two black tabs on each side of the disc tray. The second tab is located in the same location on opposite side of marked tab.
    • While pinching both tabs, slightly push the disc tray towards the front of the device, and lift the disc tray out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 705
