Ana içeriğe geç
Samsung BD-H5100 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung BD-H5100 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use the Phillips Head #2 screwdriver to remove the three 10mm screws on the back panel.
  2. Samsung BD-H5100 Motherboard Replacement: adım 2, 3 resimden 1. Samsung BD-H5100 Motherboard Replacement: adım 2, 3 resimden 2. Samsung BD-H5100 Motherboard Replacement: adım 2, 3 resimden 3.
    • Use the plastic spudger to pry open the top panel.
    • Be careful not to break the ribbon connecting the motherboard on the bottom panel to the top panel.
  3. Samsung BD-H5100 Motherboard Replacement: adım 3, 2 resimden 1. Samsung BD-H5100 Motherboard Replacement: adım 3, 2 resimden 2.
    • Pull the ribbons gently from one corner by the blue tabs to remove it.
  4. Samsung BD-H5100 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the two 7.5mm screws on both sides of the disk tray with Phillips Head #2 screwdriver.
  5. Samsung BD-H5100 Motherboard Replacement: adım 5, 2 resimden 1. Samsung BD-H5100 Motherboard Replacement: adım 5, 2 resimden 2.
    • Push two small prongs on both sides inwards and push forward.
    • Remove the disk tray.
  6. Samsung BD-H5100 Motherboard Replacement: adım 6, 2 resimden 1. Samsung BD-H5100 Motherboard Replacement: adım 6, 2 resimden 2.
    • Use a Phillips Head #2 to remove the two 7.5mm screws on the black cover.
    • Remove the black cover.
  7. Samsung BD-H5100 Motherboard Replacement: adım 7, 2 resimden 1. Samsung BD-H5100 Motherboard Replacement: adım 7, 2 resimden 2.
    • Pinch the white clip and pull straight up on the power cord.
    • Remove the power cord.
  8. Samsung BD-H5100 Motherboard Replacement: adım 8, 1 resimden 1.
    • Use a Phillips Head #2 to remove the 7.5mm screw.
  9. Samsung BD-H5100 Motherboard Replacement: adım 9, 1 resimden 1.
    • Use your finger to pry the metal tab slightly up.
    • This may break after several uses.
  10. Samsung BD-H5100 Motherboard Replacement: adım 10, 1 resimden 1.
    • Slide out the Motherboard.
    • Be careful when touching the bottom because it is sharp.
Sonuç
Mira Patel
580 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Leahy Fall 2016 USF Tampa, Team 1-2, Leahy Fall 2016 üyesi
USFT-LEAHY-F16S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 528
