Ana içeriğe geç
Samsung BD-JM57C Disc Drive Replacement
Neye ihtiyacın var
  1. Samsung BD-JM57C Disc Drive Replacement, Top Cover: adım 1, 2 resimden 1. Samsung BD-JM57C Disc Drive Replacement, Top Cover: adım 1, 2 resimden 2.
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Disc Drive Replacement, Disc Drive: adım 2, 2 resimden 1. Samsung BD-JM57C Disc Drive Replacement, Disc Drive: adım 2, 2 resimden 2.
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Disc Drive Replacement: adım 3, 2 resimden 1. Samsung BD-JM57C Disc Drive Replacement: adım 3, 2 resimden 2.
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 836
