Giriş
Use this guide to install, remove, or replace the phone's antenna.
Neye ihtiyacın var
Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
Bu adımda kullanılan alet:Tweezers$4.99
Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
Pry apart the plastic tabs along the edges of the phone.
Separate the front panel from the main body of the phone using your fingers.
Remove the two 4.0 mm screws, one silver and one black, from both ends of the antenna using the Phillips 00 screwdriver.
Bir başkası bu kılavuzu tamamladı.
