Ana içeriğe geç
Samsung BlackJack II Back Casing Replacement
Neye ihtiyacın var
  1. Samsung BlackJack II Back Casing Replacement, Battery: adım 1, 3 resimden 1. Samsung BlackJack II Back Casing Replacement, Battery: adım 1, 3 resimden 2. Samsung BlackJack II Back Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung BlackJack II Back Casing Replacement: adım 2, 3 resimden 1. Samsung BlackJack II Back Casing Replacement: adım 2, 3 resimden 2. Samsung BlackJack II Back Casing Replacement: adım 2, 3 resimden 3.
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung BlackJack II Back Casing Replacement, Back Casing: adım 3, 2 resimden 1. Samsung BlackJack II Back Casing Replacement, Back Casing: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
    • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung BlackJack II Back Casing Replacement: adım 4, 1 resimden 1.
    • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung BlackJack II Back Casing Replacement: adım 5, 3 resimden 1. Samsung BlackJack II Back Casing Replacement: adım 5, 3 resimden 2. Samsung BlackJack II Back Casing Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool in the gap between the back panel and rest of the body.
    • Slide the tool along the edges until the two pieces come apart.
    • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Ryan Rumsey
8 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-1, Maness Winter 2013 Cal Poly, Team 20-1, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 41
Her zaman: 634
