Ana içeriğe geç
Samsung Blackjack Back Phone Casing Replacement
Neye ihtiyacın var
  1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: adım 1, 3 resimden 1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: adım 1, 3 resimden 2. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: adım 1, 3 resimden 3.
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Back Phone Casing Replacement, Battery: adım 2, 2 resimden 1. Samsung Blackjack Back Phone Casing Replacement, Battery: adım 2, 2 resimden 2.
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Back Phone Casing Replacement, SIM Card: adım 3, 3 resimden 1. Samsung Blackjack Back Phone Casing Replacement, SIM Card: adım 3, 3 resimden 2. Samsung Blackjack Back Phone Casing Replacement, SIM Card: adım 3, 3 resimden 3.
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: adım 4, 2 resimden 1. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: adım 4, 2 resimden 2.
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Back Phone Casing Replacement: adım 5, 3 resimden 1. Samsung Blackjack Back Phone Casing Replacement: adım 5, 3 resimden 2. Samsung Blackjack Back Phone Casing Replacement: adım 5, 3 resimden 3.
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Sonuç
Kristin Manna
29 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 650
