Ana içeriğe geç
Samsung Blackjack Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Blackjack Motherboard Replacement, Back Phone Casing: adım 1, 2 resimden 1. Samsung Blackjack Motherboard Replacement, Back Phone Casing: adım 1, 2 resimden 2.
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  2. Samsung Blackjack Motherboard Replacement: adım 2, 3 resimden 1. Samsung Blackjack Motherboard Replacement: adım 2, 3 resimden 2. Samsung Blackjack Motherboard Replacement: adım 2, 3 resimden 3.
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  3. Samsung Blackjack Motherboard Replacement, Volume/Scroll Wheel: adım 3, 2 resimden 1. Samsung Blackjack Motherboard Replacement, Volume/Scroll Wheel: adım 3, 2 resimden 2.
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  4. Samsung Blackjack Motherboard Replacement: adım 4, 2 resimden 1. Samsung Blackjack Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
  5. Samsung Blackjack Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Samsung Blackjack Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  6. Samsung Blackjack Motherboard Replacement: adım 6, 2 resimden 1. Samsung Blackjack Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  7. Samsung Blackjack Motherboard Replacement: adım 7, 2 resimden 1. Samsung Blackjack Motherboard Replacement: adım 7, 2 resimden 2.
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
Sonuç
Kristin Manna
29 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 507
