Ana içeriğe geç
Samsung Blackjack Speaker Replacement
Neye ihtiyacın var
  1. Samsung Blackjack Speaker Replacement, Battery Cover: adım 1, 3 resimden 1. Samsung Blackjack Speaker Replacement, Battery Cover: adım 1, 3 resimden 2. Samsung Blackjack Speaker Replacement, Battery Cover: adım 1, 3 resimden 3.
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Speaker Replacement, Battery: adım 2, 2 resimden 1. Samsung Blackjack Speaker Replacement, Battery: adım 2, 2 resimden 2.
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Speaker Replacement, SIM Card: adım 3, 3 resimden 1. Samsung Blackjack Speaker Replacement, SIM Card: adım 3, 3 resimden 2. Samsung Blackjack Speaker Replacement, SIM Card: adım 3, 3 resimden 3.
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Speaker Replacement, Back Phone Casing: adım 4, 2 resimden 1. Samsung Blackjack Speaker Replacement, Back Phone Casing: adım 4, 2 resimden 2.
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Speaker Replacement: adım 5, 3 resimden 1. Samsung Blackjack Speaker Replacement: adım 5, 3 resimden 2. Samsung Blackjack Speaker Replacement: adım 5, 3 resimden 3.
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Speaker Replacement, Motherboard: adım 6, 2 resimden 1. Samsung Blackjack Speaker Replacement, Motherboard: adım 6, 2 resimden 2.
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
  7. Samsung Blackjack Speaker Replacement: adım 7, 2 resimden 1. Samsung Blackjack Speaker Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
  8. Samsung Blackjack Speaker Replacement: adım 8, 2 resimden 1. Samsung Blackjack Speaker Replacement: adım 8, 2 resimden 2.
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
  9. Samsung Blackjack Speaker Replacement, Speaker: adım 9, 2 resimden 1. Samsung Blackjack Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Use the spudger to wedge between the speaker and the speaker's casing.
    • Use the spudger to pry on the speaker until it comes free from the casing.
Sonuç
Kristin Manna
29 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 10
Her zaman: 438
