Ana içeriğe geç
Samsung Blackjack Volume/Scroll Wheel Replacement
Neye ihtiyacın var
  1. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: adım 1, 3 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: adım 1, 3 resimden 2. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery Cover: adım 1, 3 resimden 3.
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery: adım 2, 2 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement, Battery: adım 2, 2 resimden 2.
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: adım 3, 3 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: adım 3, 3 resimden 2. Samsung Blackjack Volume/Scroll Wheel Replacement, SIM Card: adım 3, 3 resimden 3.
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Volume/Scroll Wheel Replacement, Back Phone Casing: adım 4, 2 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement, Back Phone Casing: adım 4, 2 resimden 2.
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Volume/Scroll Wheel Replacement: adım 5, 3 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement: adım 5, 3 resimden 2. Samsung Blackjack Volume/Scroll Wheel Replacement: adım 5, 3 resimden 3.
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
  6. Samsung Blackjack Volume/Scroll Wheel Replacement, Volume/Scroll Wheel: adım 6, 2 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement, Volume/Scroll Wheel: adım 6, 2 resimden 2.
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
  7. Samsung Blackjack Volume/Scroll Wheel Replacement: adım 7, 2 resimden 1. Samsung Blackjack Volume/Scroll Wheel Replacement: adım 7, 2 resimden 2.
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
Sonuç
Kristin Manna
29 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 üyesi
CLEM-BENSON-F12S14G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 540
