Ana içeriğe geç
Samsung Blast Keyboard Replacement
Neye ihtiyacın var
  1. Samsung Blast Keyboard Replacement, At a Glance: adım 1, 2 resimden 1. Samsung Blast Keyboard Replacement, At a Glance: adım 1, 2 resimden 2.
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: adım 2, 2 resimden 1. Samsung Blast Keyboard Replacement, Battery Case Removal: adım 2, 2 resimden 2.
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: adım 3, 1 resimden 1.
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: adım 4, 2 resimden 1. Samsung Blast Keyboard Replacement, Back Case Removal: adım 4, 2 resimden 2.
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: adım 5, 2 resimden 1. Samsung Blast Keyboard Replacement, Button Pads: adım 5, 2 resimden 2.
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: adım 6, 3 resimden 1. Samsung Blast Keyboard Replacement, Motherboard Removal: adım 6, 3 resimden 2. Samsung Blast Keyboard Replacement, Motherboard Removal: adım 6, 3 resimden 3.
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: adım 7, 2 resimden 1. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: adım 7, 2 resimden 2.
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Sonuç
Jordan Taylor
10 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Spring 2014 Ohio State, Team 1-5, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 318
