Ana içeriğe geç
Samsung Blast Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Blast Motherboard  Replacement, Motherboard: adım 1, 2 resimden 1. Samsung Blast Motherboard  Replacement, Motherboard: adım 1, 2 resimden 2.
    • Remove the battery cover by pushing it upwards.
  2. Samsung Blast Motherboard  Replacement: adım 2, 1 resimden 1.
    • Take out the battery.
  3. Samsung Blast Motherboard  Replacement: adım 3, 1 resimden 1.
    • With a Phillips #00 screwdriver, remove the six screws that secure the back of the case.
    • You will not be able to completely remove the top two screws. Simply loosen them enough that you can still remove the cover.
  4. Samsung Blast Motherboard  Replacement: adım 4, 1 resimden 1.
    • Pull off the back cover of the phone.
  5. Samsung Blast Motherboard  Replacement: adım 5, 2 resimden 1. Samsung Blast Motherboard  Replacement: adım 5, 2 resimden 2.
    • Remove the volume and camera buttons by pulling them out.
    • Put the buttons aside until it is time to reassemble the phone.
  6. Samsung Blast Motherboard  Replacement: adım 6, 1 resimden 1.
    • Use the small plastic opening tool to gently remove the motherboard from the rest of the phone.
  7. Samsung Blast Motherboard  Replacement: adım 7, 2 resimden 1. Samsung Blast Motherboard  Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Gently grab the motherboard with tweezers, then disconnect it from the two attached plates.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paige Weinstein
1 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Spring 2014 Ohio State, Team 1-5, Buehl Spring 2014 üyesi
OSU-BUEHL-S14S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 434
