Ana içeriğe geç
Samsung Brightside Logic board Replacement
Neye ihtiyacın var
  1. Samsung Brightside Logic board Replacement, Logic board: adım 1, 3 resimden 1. Samsung Brightside Logic board Replacement, Logic board: adım 1, 3 resimden 2. Samsung Brightside Logic board Replacement, Logic board: adım 1, 3 resimden 3.
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Logic board Replacement: adım 2, 3 resimden 1. Samsung Brightside Logic board Replacement: adım 2, 3 resimden 2. Samsung Brightside Logic board Replacement: adım 2, 3 resimden 3.
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Logic board Replacement: adım 3, 3 resimden 1. Samsung Brightside Logic board Replacement: adım 3, 3 resimden 2. Samsung Brightside Logic board Replacement: adım 3, 3 resimden 3.
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Logic board Replacement: adım 4, 3 resimden 1. Samsung Brightside Logic board Replacement: adım 4, 3 resimden 2. Samsung Brightside Logic board Replacement: adım 4, 3 resimden 3.
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Logic board Replacement: adım 5, 2 resimden 1. Samsung Brightside Logic board Replacement: adım 5, 2 resimden 2.
    • Detach the LCD connector.
    • Remove the logic board
Sonuç
Bir başkası bu kılavuzu tamamladı.
oldturkey03
791.325 İtibar
119 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
35 Üyeler
603 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,559
