Ana içeriğe geç
Samsung CLP-300 Black Toner Transfer Unit Replacement
Neye ihtiyacın var
  1. Samsung CLP-300 Black Toner Transfer Unit Replacement, Black Toner Transfer Unit: adım 1, 1 resimden 1.
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 2, 1 resimden 1.
    • Pull paper tray out and set aside.
  3. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 3, 2 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 3, 2 resimden 2.
    • Open the front cover.
  4. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 4, 1 resimden 1.
    • Pull the waste toner container out of the printer using the handle.
    • Make sure to keep waste toner container upright to avoid spillage.
  5. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 5, 3 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 5, 3 resimden 2. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 5, 3 resimden 3.
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • At this point you can set the printer aside as you will only need the imaging unit to continue repair.
  6. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 6, 2 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 6, 2 resimden 2.
    • Remove these two screws.
    • Do not expose imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
  7. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 7, 1 resimden 1.
    • Carefully pry plastic arm away from main unit.
  8. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 8, 3 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 8, 3 resimden 2. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 8, 3 resimden 3.
    • Carefully pry plastic from screw base so that the entire organic photo conductor piece slides open to the left.
    • When removing the organic photo conductor take care to not lose the small spring on the back left.
    • At this point you may want to put on plastic gloves to keep from staining hands with printer ink.
  9. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 9, 2 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 9, 2 resimden 2.
    • Slide each toner transfer unit out separately, placing all aside except for the black toner transfer unit.
    • Keep toner rollers level to avoid toner spillage.
  10. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 10, 3 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 10, 3 resimden 2. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 10, 3 resimden 3.
    • Remove these five screws from the top of the black toner transfer unit.
    • Remove main and smaller z-shaped plates.
  11. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 11, 2 resimden 1. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 11, 2 resimden 2.
    • Remove these three screws from the right end of the toner transfer unit.
  12. Samsung CLP-300 Black Toner Transfer Unit Replacement: adım 12, 1 resimden 1.
    • Remove plastic end piece.
    • Gently pull out black toner roller.
    • Insert new roller in place of old roller turning slightly to fit.
    • Be careful not to pinch small foam square when inserting new roller.
    • Cover new roller with toner by rotating roller by hand.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Heather Howard
586 İtibar
4 adet Kılavuz yazıldı
Ekip
University of Maine, Team 1-1, Diaz Fall 2014 University of Maine, Team 1-1, Diaz Fall 2014 üyesi
UMAINE-DIAZ-F14S1G1
3 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
I need more information pertaining step 8. In order to separate the parts, in which directions should the be moved first and where is the best point to apply force ?
Bernd Dreyer - Yanıt
I need more information for step 12: I removed the old roller. Unfortunately I don't know anymore how exactly the metal discs and the white plastic rings are placed.
Daniel Roller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 3,282
