Ana içeriğe geç
Samsung Captivate Antenna Cable Replacement
Neye ihtiyacın var
    1. Samsung Captivate Antenna Cable Replacement, Battery: adım 1, 1 resimden 1.
      • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
      • Lift up the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Captivate Antenna Cable Replacement: adım 2, 1 resimden 1.
      • Place your finger on the bottom of the battery and lift to remove.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Captivate Antenna Cable Replacement: adım 3, 1 resimden 1.
      • Replace the old battery with the new one.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Captivate Antenna Cable Replacement, Rear Case: adım 4, 1 resimden 1.
      • Insert the spudger underneath the bottom section of the phone.
      • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Captivate Antenna Cable Replacement: adım 5, 1 resimden 1.
      • Remove the six 4.5mm #000 Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Captivate Antenna Cable Replacement: adım 6, 3 resimden 1. Samsung Captivate Antenna Cable Replacement: adım 6, 3 resimden 2. Samsung Captivate Antenna Cable Replacement: adım 6, 3 resimden 3.
      • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
      • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
      • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Captivate Antenna Cable Replacement: adım 7, 1 resimden 1.
      • Separate the rear case from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Captivate Antenna Cable Replacement, Antenna Cable: adım 8, 2 resimden 1. Samsung Captivate Antenna Cable Replacement, Antenna Cable: adım 8, 2 resimden 2.
      • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
      • Pry up the other end of the cable from the connector on the antenna array.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Drew Bentz
565 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G25
3 Üyeler
81 adet Kılavuz yazıldı
2Kılavuz Yorumları
Quick question, is this the antenna for wifi or cellular network?
Michael Perdomo - Yanıt Paylaş
This is actually just the cable that connects the motherboard to the antenna array. I believe the antenna array that it connects to is for WiFi though.
Drew Bentz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 44
Her zaman: 4,150
