Giriş
If you receive an error message when attempting to use your camera, and resetting to factory settings did not fix it, then you need to replace the camera or ensure that your camera is connected to the motherboard. At times, if you've dropped your phone, the camera may detach from the motherboard.
Neye ihtiyacın var
Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
Bir başkası bu kılavuzu tamamladı.
