Ana içeriğe geç
Samsung Captivate Glide QWERTY Keyboard Replacement
Neye ihtiyacın var
  1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: adım 1, 3 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: adım 1, 3 resimden 2. Samsung Captivate Glide QWERTY Keyboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 2, 2 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 3, 2 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 4, 3 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 4, 3 resimden 2. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 4, 3 resimden 3.
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 5, 2 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 7, 1 resimden 1.
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 8, 2 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 8, 2 resimden 2.
    • Lift the motherboard out of the base of the phone.
  9. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: adım 9, 2 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement, QWERTY Keyboard: adım 9, 2 resimden 2.
    • Remove the eight screws using the #00 screw driver.
  10. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 10, 2 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 10, 2 resimden 2.
  11. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 11, 1 resimden 1.
    • Remove screws using the #00 screwdriver.
  12. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 12, 1 resimden 1.
    • Using the plastic opening tool, remove the back plate by prying on the four main points.
    • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
  13. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 13, 1 resimden 1.
    • Lift the back plate.
    • To remove the attached flex cable, gently peel the flex cable connecting to the back plate.
    • Flex cable is attached to the back plate with an adhesive.
  14. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 14, 3 resimden 1. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 14, 3 resimden 2. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 14, 3 resimden 3.
    • Slide the flex cable through the slot.
    • Set the front plate down. Now you have free access to the keyboard.
  15. Samsung Captivate Glide QWERTY Keyboard Replacement: adım 15, 1 resimden 1.
    • Manually lift the keyboard and replace with new keyboard.
    • Make sure the new keyboard is placed with the keyboard letters facing down, and the white back facing up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Martinez
260 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-3, Mcgee Fall 2014 USF Tampa, Team 5-3, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 472
