Ana içeriğe geç
Samsung Captivate Glide Screen Replacement
Neye ihtiyacın var
    1. Samsung Captivate Glide Screen Replacement, Motherboard: adım 1, 3 resimden 1. Samsung Captivate Glide Screen Replacement, Motherboard: adım 1, 3 resimden 2. Samsung Captivate Glide Screen Replacement, Motherboard: adım 1, 3 resimden 3.
      • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Captivate Glide Screen Replacement: adım 2, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 2, 2 resimden 2.
      • Remove battery with plastic opening tool or finger.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Captivate Glide Screen Replacement: adım 3, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 3, 2 resimden 2.
      • Remove the seven screws from backplate using the #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Captivate Glide Screen Replacement: adım 4, 3 resimden 1. Samsung Captivate Glide Screen Replacement: adım 4, 3 resimden 2. Samsung Captivate Glide Screen Replacement: adım 4, 3 resimden 3.
      • Remove the back plate using the plastic opening tool.
      • There is a lip on each side, and both must be pried up.
      • You can work your way around the edges after prying the two sides.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Captivate Glide Screen Replacement: adım 5, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 5, 2 resimden 2.
      • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Captivate Glide Screen Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Disconnect the antenna cable from the motherboard using tweezers.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Captivate Glide Screen Replacement: adım 7, 1 resimden 1.
      • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Captivate Glide Screen Replacement: adım 8, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 8, 2 resimden 2.
      • Lift the motherboard out of the base of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Samsung Captivate Glide Screen Replacement, Screen: adım 9, 2 resimden 1. Samsung Captivate Glide Screen Replacement, Screen: adım 9, 2 resimden 2.
      • Remove the eight screws with the #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Captivate Glide Screen Replacement: adım 10, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 10, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Captivate Glide Screen Replacement: adım 11, 1 resimden 1.
      • Remove screws with the #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Captivate Glide Screen Replacement: adım 12, 1 resimden 1.
      • Using the plastic opening tool, remove the back plate by prying on the four main points.
      • You may encounter difficultly at certain points. Work the plastic opening tool along the edge to keep back plate from closing again.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Captivate Glide Screen Replacement: adım 13, 1 resimden 1.
      • Lift the back plate.
      • To remove to slide flex cable, gently peel back from the back plate and remove back plate.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Captivate Glide Screen Replacement: adım 14, 3 resimden 1. Samsung Captivate Glide Screen Replacement: adım 14, 3 resimden 2. Samsung Captivate Glide Screen Replacement: adım 14, 3 resimden 3.
      • Slide the flex cable through the slot. Be careful to not tear the cable.
      • Set the front plate down.
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Captivate Glide Screen Replacement: adım 15, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 15, 2 resimden 2.
      • Remove the four corner screws using the #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Captivate Glide Screen Replacement: adım 16, 3 resimden 1. Samsung Captivate Glide Screen Replacement: adım 16, 3 resimden 2. Samsung Captivate Glide Screen Replacement: adım 16, 3 resimden 3.
      • Using the plastic opening tool, release all the clips on all four sides holding the screen assembly.
      • You can now remove the back plate by sliding the flex cable through the slot.
      FixBot'a Sor
      Yorum Ekle
    9. Samsung Captivate Glide Screen Replacement: adım 17, 3 resimden 1. Samsung Captivate Glide Screen Replacement: adım 17, 3 resimden 2. Samsung Captivate Glide Screen Replacement: adım 17, 3 resimden 3.
      • Use the plastic opening tool to release the main jaw connector, front speaker and camera.
      FixBot'a Sor
      Yorum Ekle
    10. Samsung Captivate Glide Screen Replacement: adım 18, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 18, 2 resimden 2.
      • By using the plastic opening tool you can release the keypad flex cable from the jaw connecter clamp.
      FixBot'a Sor
      Yorum Ekle
    11. Samsung Captivate Glide Screen Replacement: adım 19, 2 resimden 1. Samsung Captivate Glide Screen Replacement: adım 19, 2 resimden 2.
      • Use a heat gun or blow dryer.
      • Heat the outside edges using quick movements for about 45 seconds.
      FixBot'a Sor
      Yorum Ekle
    12. Samsung Captivate Glide Screen Replacement: adım 20, 3 resimden 1. Samsung Captivate Glide Screen Replacement: adım 20, 3 resimden 2. Samsung Captivate Glide Screen Replacement: adım 20, 3 resimden 3.
      • Using the plastic opening tool to pry around the edges, release the touch screen from the screen frame.
      FixBot'a Sor
      Yorum Ekle
    13. Samsung Captivate Glide Screen Replacement: adım 21, 3 resimden 1. Samsung Captivate Glide Screen Replacement: adım 21, 3 resimden 2. Samsung Captivate Glide Screen Replacement: adım 21, 3 resimden 3.
      • While adhesive is still warm, use the plastic opening tool to gently remove the keyboard flex cable from the screen.
      • You can now replace the screen assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tyler Moore
160 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 5-3, Mcgee Fall 2014 USF Tampa, Team 5-3, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G3
4 Üyeler
40 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,333
