Ana içeriğe geç
Samsung Captivate Rear Case Replacement
Neye ihtiyacın var
  1. Samsung Captivate Rear Case Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: adım 2, 1 resimden 1.
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: adım 3, 1 resimden 1.
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: adım 4, 1 resimden 1.
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: adım 5, 1 resimden 1.
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: adım 6, 3 resimden 1. Samsung Captivate Rear Case Replacement: adım 6, 3 resimden 2. Samsung Captivate Rear Case Replacement: adım 6, 3 resimden 3.
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: adım 7, 1 resimden 1.
    • Separate the rear case from the phone.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Christopher
643 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-25, Maness Fall 2011 Cal Poly, Team 20-25, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G25
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 27
Her zaman: 3,604
