Ana içeriğe geç
Samsung Chromebook 2 Battery Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Chromebook 2 Battery Replacement: adım 2, 3 resimden 1. Samsung Chromebook 2 Battery Replacement: adım 2, 3 resimden 2. Samsung Chromebook 2 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Chromebook 2 Battery Replacement: adım 3, 2 resimden 1. Samsung Chromebook 2 Battery Replacement: adım 3, 2 resimden 2.
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Chromebook 2 Battery Replacement: adım 4, 2 resimden 1. Samsung Chromebook 2 Battery Replacement: adım 4, 2 resimden 2.
    • Once the cover is loose, remove the back cover panel using your hands.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Chromebook 2 Battery Replacement: adım 5, 2 resimden 1. Samsung Chromebook 2 Battery Replacement: adım 5, 2 resimden 2.
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Chromebook 2 Battery Replacement: adım 6, 3 resimden 1. Samsung Chromebook 2 Battery Replacement: adım 6, 3 resimden 2. Samsung Chromebook 2 Battery Replacement: adım 6, 3 resimden 3.
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Allan
121 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Rose Winter 2016 UW Tacoma, Team 1-3, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G3
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 50
Her zaman: 2,002
