Giriş
You may need to perform this replacement if you are experiencing noticeably reduced battery life from your current unit, or your current battery will not recharge. Ensure your device is powered off before beginning this replacement.
Neye ihtiyacın var
Make sure your Chromebook is turned off before you begin.
Set the labtop face down on a flat surface.
3 farklı kişi bu kılavuzu tamamladı.
