Ana içeriğe geç
Samsung Chromebook 2 Screen Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 2 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
  2. Samsung Chromebook 2 Screen Replacement: adım 2, 3 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 2, 3 resimden 2. Samsung Chromebook 2 Screen Replacement: adım 2, 3 resimden 3.
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
  3. Samsung Chromebook 2 Screen Replacement: adım 3, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 3, 2 resimden 2.
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
  4. Samsung Chromebook 2 Screen Replacement: adım 4, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 4, 2 resimden 2.
    • Once the cover is loose, remove the back cover panel using your hands.
  5. Samsung Chromebook 2 Screen Replacement: adım 5, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 5, 2 resimden 2.
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
  6. Samsung Chromebook 2 Screen Replacement: adım 6, 3 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 6, 3 resimden 2. Samsung Chromebook 2 Screen Replacement: adım 6, 3 resimden 3.
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
  7. Samsung Chromebook 2 Screen Replacement, Screen: adım 7, 2 resimden 1. Samsung Chromebook 2 Screen Replacement, Screen: adım 7, 2 resimden 2.
    • Replace the back cover by clicking it into place with your hands.
    • No need to replace the screws, this is just to protect the internal hardware while working on the screen.
  8. Samsung Chromebook 2 Screen Replacement: adım 8, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 8, 2 resimden 2.
    • Open the laptop and place it so that the back of the screen is laying on a flat surface.
    • Insert a plastic opening tool between the front cover and plastic screen trim.
    • Work the plastic opening tool all around the trim.
    • Don't be afraid to use your hands to pull the trim from the front panel.
  9. Samsung Chromebook 2 Screen Replacement: adım 9, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 9, 2 resimden 2.
    • Flip the computer over so that the keys and screen are facing down.
    • Insert the spudger between the back and front panel, at the hinge, and push the trim out.
  10. Samsung Chromebook 2 Screen Replacement: adım 10, 1 resimden 1.
    • Place the laptop in a position where it is resting on the back of the screen.
    • Remove the trim from the front panel by pulling up with your hands.
  11. Samsung Chromebook 2 Screen Replacement: adım 11, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 11, 2 resimden 2.
    • Using a Phillips #0 screwdriver to unscrew the four 3 mm screws keeping the screen in place.
  12. Samsung Chromebook 2 Screen Replacement: adım 12, 2 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 12, 2 resimden 2.
    • Using the spudger, pry the screen loose from the front panel.
    • Do not try to remove the screen yet, it is still connect by a wire.
  13. Samsung Chromebook 2 Screen Replacement: adım 13, 3 resimden 1. Samsung Chromebook 2 Screen Replacement: adım 13, 3 resimden 2. Samsung Chromebook 2 Screen Replacement: adım 13, 3 resimden 3.
    • Place the laptop in an upright position.
    • When you place the Chromebook in this position the screen may fall off, so make sure to hold onto it.
    • Pull back the screen to locate the LCD cable, and disconnect it by pulling the black tape that surrounds it towards you.
  14. Samsung Chromebook 2 Screen Replacement: adım 14, 1 resimden 1.
    • Pull the screen from the front panel using your hands to fully remove it.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
MacKenzie Colson
655 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Rose Winter 2016 UW Tacoma, Team 1-3, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G3
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 39
Her zaman: 7,493
