Ana içeriğe geç
Samsung Chromebook 2 Trackpad Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 2 Trackpad Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
  2. Samsung Chromebook 2 Trackpad Replacement: adım 2, 3 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 2, 3 resimden 2. Samsung Chromebook 2 Trackpad Replacement: adım 2, 3 resimden 3.
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
  3. Samsung Chromebook 2 Trackpad Replacement: adım 3, 2 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 3, 2 resimden 2.
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
  4. Samsung Chromebook 2 Trackpad Replacement: adım 4, 2 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 4, 2 resimden 2.
    • Once the cover is loose, remove the back cover panel using your hands.
  5. Samsung Chromebook 2 Trackpad Replacement: adım 5, 2 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 5, 2 resimden 2.
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
  6. Samsung Chromebook 2 Trackpad Replacement: adım 6, 3 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 6, 3 resimden 2. Samsung Chromebook 2 Trackpad Replacement: adım 6, 3 resimden 3.
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
  7. Samsung Chromebook 2 Trackpad Replacement, Trackpad: adım 7, 3 resimden 1. Samsung Chromebook 2 Trackpad Replacement, Trackpad: adım 7, 3 resimden 2. Samsung Chromebook 2 Trackpad Replacement, Trackpad: adım 7, 3 resimden 3.
    • Using the Phillips #00 screwdriver, remove the three 2 mm screws keeping the trackpad in place.
  8. Samsung Chromebook 2 Trackpad Replacement: adım 8, 3 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 8, 3 resimden 2. Samsung Chromebook 2 Trackpad Replacement: adım 8, 3 resimden 3.
    • Remove the connector between the trackpad and the motherboard by pulling upwards on it at the port.
  9. Samsung Chromebook 2 Trackpad Replacement: adım 9, 2 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Heavy-Duty Spudger
  10. Samsung Chromebook 2 Trackpad Replacement: adım 10, 2 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 10, 2 resimden 2.
    • Use a plastic opening tool to disconnect the metal trackpad support brackets.
    • Don't be afraid to use a moderate amount of force when prying the support brackets loose.
  11. Samsung Chromebook 2 Trackpad Replacement: adım 11, 3 resimden 1. Samsung Chromebook 2 Trackpad Replacement: adım 11, 3 resimden 2. Samsung Chromebook 2 Trackpad Replacement: adım 11, 3 resimden 3.
    • With the laptop slightly open, push the trackpad upwards at the rear, and pull it out from the bottom.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sebastian Baba
436 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Rose Winter 2016 UW Tacoma, Team 1-3, Rose Winter 2016 üyesi
UWT-ROSE-W16S1G3
4 Üyeler
4 adet Kılavuz yazıldı
2Kılavuz Yorumları
Olá, gostei do site , pois apresenta um conteúdo bem rico em conhecimento gostaria de uma assistência sempre uso os métodos de reparo do site sempre da certo , porém não visualizei os manuais de reparo toubleshoting , ficaria muito agradecido caso vocês envie esses arquivos pra mim aprofundar meus conhecimentos da área de eletrônica .
atenciosamente.
jordson Martins Dantas - Yanıt
Reassembly Note: It should be noted that the trackpad will not "click" if the 2mm screws in STEP 7 are tight. Screw down until just snug then back off slightly. The bracket will then function correctly to return the trackpad to the up position after each click depress.
Nathan B. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 3,710
