Ana içeriğe geç
Samsung Chromebook 2 XE503c12 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 2, 2 resimden 1. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 3, 2 resimden 1. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 4, 1 resimden 1.
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Locate the motherboard at top right of chromebook.
    • Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
  7. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 7, 2 resimden 1. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove auxiliary wires for microphone and webcam.
  8. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 8, 2 resimden 1. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift hinge on connector up and pull the connector away from the device.
  9. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove the connector for the motherboard and sub-board.
  10. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the connector for motherboard and chromebook.
  11. Samsung Chromebook 2 XE503c12 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 478
