Ana içeriğe geç
Samsung Chromebook 2 XE503c12 Speakers Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 2 XE503c12 Speakers Replacement, Battery: adım 1, 2 resimden 1. Samsung Chromebook 2 XE503c12 Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 2, 2 resimden 1. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 3, 2 resimden 1. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 3, 2 resimden 2.
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 4, 1 resimden 1.
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 5, 1 resimden 1.
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Speakers Replacement, Speakers: adım 6, 2 resimden 1. Samsung Chromebook 2 XE503c12 Speakers Replacement, Speakers: adım 6, 2 resimden 2.
    • Remove the connectors for each speaker.
  7. Samsung Chromebook 2 XE503c12 Speakers Replacement: adım 7, 1 resimden 1.
    • Remove two 7mm Phillips #0 screws from each speaker.
    • Pull speakers out of laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 120
