Ana içeriğe geç
Samsung Chromebook 3 Battery Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 3 Battery Replacement, Bottom Case: adım 1, 2 resimden 1. Samsung Chromebook 3 Battery Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Battery Replacement: adım 2, 3 resimden 1. Samsung Chromebook 3 Battery Replacement: adım 2, 3 resimden 2. Samsung Chromebook 3 Battery Replacement: adım 2, 3 resimden 3.
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Battery Replacement: adım 3, 1 resimden 1.
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Battery Replacement, Battery: adım 4, 2 resimden 1. Samsung Chromebook 3 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Battery Replacement: adım 5, 2 resimden 1. Samsung Chromebook 3 Battery Replacement: adım 5, 2 resimden 2.
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Battery Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and out from the case.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Austin Blakely
19.506 İtibar
53 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
Bir Yorum
Can you fix my chromebook
Peter Hancocks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,507
