Ana içeriğe geç
Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: adım 1, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: adım 2, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: adım 2, 2 resimden 2.
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: adım 3, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Bottom Case Replacement: adım 3, 2 resimden 2.
    • Remove the cover exposing the inside of the laptop.
Sonuç
Mick McCarty
980 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 344
