Ana içeriğe geç
Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: adım 1, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: adım 1, 2 resimden 2.
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 2, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 2, 2 resimden 2.
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 3, 3 resimden 1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 3, 3 resimden 2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 3, 3 resimden 3.
    • Disconnect black and white wire from the I/O board.
    • Remove two 4.6 mm screws from the display hinge using a Phillips #00 screwdriver.
    • Rotate both display hinges upward, away from the components.
  4. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 4, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 4, 2 resimden 2.
    • Remove the nuts with a 5 mm nut driver socket.
    • Remove all six washers from each side.
  5. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: adım 5, 1 resimden 1.
    • Remove the hinges from the bar on both sides.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caden Smith
397 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-3, Harley Spring 2023 IUPUI, Team 3-3, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S3G3
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 102
