Ana içeriğe geç
Samsung Chromebook 3 XE500C13-K02US Track pad Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: adım 1, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 2, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 2, 2 resimden 2.
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 3, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 3, 2 resimden 2.
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: adım 4, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Battery: adım 4, 2 resimden 2.
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 5, 3 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 5, 3 resimden 2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 5, 3 resimden 3.
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: adım 7, 2 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement, Track pad: adım 7, 2 resimden 2.
    • Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 8, 3 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 8, 3 resimden 2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 8, 3 resimden 3.
    • Remove the ribbon cable by lifting it out of the connector.
    • Lift the grey adhesive tape.
  9. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 9, 3 resimden 1. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 9, 3 resimden 2. Samsung Chromebook 3 XE500C13-K02US Track pad Replacement: adım 9, 3 resimden 3.
    • Lift the track pad from the top.
    • Slide the track pad away from yourself to clear the black plastic edge.
    • Lift the track pad up and out of the laptop.
Sonuç
Mick McCarty
980 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 254
