Hold the power button on the keyboard until the device powers off.
Close the device and flip it over.
Remove the four rubber sockets on each corner of the device with your fingers.
Remove the four 4.6 mm screws with a Phillips #00 screwdriver.
Locate a long gray box labeled “Laptop Battery.”
Remove the two 4 mm screws with a Phillips #00 screwdriver.
After removing the screws, remove the gray piece labeled “bracket battery BA61 - 03983A.” This piece is located over the golden band connecting the battery and the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
