Ana içeriğe geç
Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement, Battery: adım 1, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement, Battery: adım 1, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Hold the power button on the keyboard until the device powers off.
    • Close the device and flip it over.
    • Remove the four rubber sockets on each corner of the device with your fingers.
    • Remove the four 4.6 mm screws with a Phillips #00 screwdriver.
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement: adım 2, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement: adım 2, 2 resimden 2.
    • Starting near the hinges, use a metal spudger to gently pry the back off. Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement: adım 3, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement: adım 3, 2 resimden 2.
    • Locate a long gray box labeled “Laptop Battery.”
    • Remove the two 4 mm screws with a Phillips #00 screwdriver.
    • After removing the screws, remove the gray piece labeled “bracket battery BA61 - 03983A.” This piece is located over the golden band connecting the battery and the motherboard.
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Battery Replacement: adım 4, 1 resimden 1.
    • Unplug the golden band that connects the battery to the motherboard.
    • Use the Phillips #000 screwdriver to remove the four 4 mm screws holding the battery in place.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Austyn Akin
270 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 724
