Ana içeriğe geç
Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: adım 1, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: adım 1, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Hold the power button on the keyboard until the device powers off.
    • Close the device and flip it over.
    • Remove the four rubber sockets on each corner of the device with your fingers.
    • Remove the four 4.6 mm screws with a Phillips #00 screwdriver.
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 2, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 2, 2 resimden 2.
    • Starting near the hinges, use a metal spudger to gently pry the back off. Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 3, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 3, 2 resimden 2.
    • Locate a long gray box labeled “Laptop Battery.”
    • Remove the two 4 mm screws with a Phillips #00 screwdriver.
    • After removing the screws, remove the gray piece labeled “bracket battery BA61 - 03983A.” This piece is located over the golden band connecting the battery and the motherboard.
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 4, 1 resimden 1.
    • Unplug the golden band that connects the battery to the motherboard.
    • Use the Phillips #000 screwdriver to remove the four 4 mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: adım 5, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: adım 5, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement, Motherboard: adım 5, 3 resimden 3.
    • Unplug the black and red wire and the black and white wire.
    • Unclip and remove the black and gold ribbons and the black wire from the motherboard.
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 6, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 6, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 6, 3 resimden 3.
    • Remove the three 4.53 mm Philips #00 screws from the grey metal piece labeled "BRKT-PORT-SUB JOAN-15 BA61-03942A".
    • Remove the 4.50 mm Philips #00 screw from the right side of the motherboard.
  7. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the two 4.56 mm Philips #00 screws from the copper heat sink.
    • Remove the four 4.63 mm Philips #00 screws
  8. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 8, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Motherboard Replacement: adım 8, 2 resimden 2.
    • Carefully turn the motherboard and heat sink over being careful not to touch any of the components.
    • Remove the four 4.63 mm Philips #00 screws from the back of the motherboard and remove the heat sink.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katherine Vu
378 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 48
Her zaman: 728
