Ana içeriğe geç
Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement
  1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: adım 1, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: adım 1, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Battery: adım 1, 3 resimden 3.
    • Hold the power button on the keyboard until the device powers off.
    • Close the device and flip it over.
    • Remove the four rubber sockets on each corner of the device with your fingers.
    • Remove the four 4.6 mm screws with a Phillips #00 screwdriver.
  2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 2, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 2, 2 resimden 2.
    • Starting near the hinges, use a metal spudger to gently pry the back off. Continue along the edges until the back is completely detached.
  3. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 3, 2 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 3, 2 resimden 2.
    • Locate a long gray box labeled “Laptop Battery.”
    • Remove the two 4 mm screws with a Phillips #00 screwdriver.
    • After removing the screws, remove the gray piece labeled “bracket battery BA61 - 03983A.” This piece is located over the golden band connecting the battery and the motherboard.
  4. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 4, 1 resimden 1.
    • Unplug the golden band that connects the battery to the motherboard.
    • Use the Phillips #000 screwdriver to remove the four 4 mm screws holding the battery in place.
  5. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: adım 5, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: adım 5, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement, Speakers: adım 5, 3 resimden 3.
    • Follow this step if your Chromebook's left speaker is broken.
    • Face the hinges of the motherboard toward you.
    • Pull out the white plug-in piece indicated in the photo.
    • Remove only the red and black wire from the wire guide, and ensure all other wires are in place.
    • Lift the black L-shaped piece called “>PC+ABS<S1-C(L) R0.0 BA96-07326A.”
  6. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 6, 3 resimden 1. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 6, 3 resimden 2. Samsung Chromebook 4 Plus XE350XBA-K05US Device Speakers Replacement: adım 6, 3 resimden 3.
    • Follow this step if your Chromebook's right speaker is broken.
    • Remove only the white and black wire from the wire guide, and ensure all other wires are in place.
    • Lift the black L-shaped piece called “>PC+ABS<S1-A(R) R0.0 BA96-07326B.”
Sonuç
Austyn Akin
270 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 223
