Ana içeriğe geç
Samsung Chromebook Pro Hinge Replacement
Neye ihtiyacın var
  1. Samsung Chromebook Pro Hinge Replacement, Hinge: adım 1, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement, Hinge: adım 1, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement, Hinge: adım 1, 3 resimden 3.
    • Remove the eight 30 mm screws from the edges of the case with the JIS J000 screw bit.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Chromebook Pro Hinge Replacement: adım 2, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 2, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 2, 3 resimden 3.
    • Slide the plastic opening tool in a corner at a steep angle, and lift up to remove the outer case.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Chromebook Pro Hinge Replacement: adım 3, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 3, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Locate the two white wires and one black wire. With the flat precision tweezers, untangle the white wires from the CONAN >PC+ABS< # 1-1.
    • Completely disconnect the black wire.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Chromebook Pro Hinge Replacement: adım 4, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 4, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 4, 3 resimden 3.
    • Remove the three 30 mm screws using the JIS J000 screw bit from the black CONAN >PC+ABS< # 1-1 plate.
    • Once all the screws are removed from the CONAN >PC+ABS< # 1-1 plate, remove the wire attached to underside and lift the plate to remove.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Chromebook Pro Hinge Replacement: adım 5, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 5, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 5, 3 resimden 3.
    • Locate hinge plates LP1 and RP1 on the top left and right corners of the Chromebook.
    • Remove the two 30 mm screws from hinge plates LP1 and RP1 using the JIS J000 screw bit.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Chromebook Pro Hinge Replacement: adım 6, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 6, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 6, 3 resimden 3.
    • On the right top corner, locate the black and gold wire.
    • Lift the bar that is locking the wire in using the precision tweezers.
    • Disconnect the wire by grasping the black portion with the precision tweezers, and then pulling away from the Chromebook Pro.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Chromebook Pro Hinge Replacement: adım 7, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 7, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 7, 3 resimden 3.
    • Completely open the Chromebook and gently separate both halves.
    • Be careful not to pull any wires.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Chromebook Pro Hinge Replacement: adım 8, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 8, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 8, 3 resimden 3.
    • Make sure the Chromebook is facing up.
    • Place the plastic opening tool at an angle in the gap between the hinge and Chromebook screen and lift up.
    • Completely remove the plastic screen lining using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Chromebook Pro Hinge Replacement: adım 9, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 9, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 9, 3 resimden 3.
    • Remove the three 30 mm screws from hinge plate R1 and L1 using the JIS J000 screw bit.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Chromebook Pro Hinge Replacement: adım 10, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 10, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 10, 3 resimden 3.
    • Disconnect the black wire on the R1 plate connected to the screen using the precision tweezers.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Chromebook Pro Hinge Replacement: adım 11, 3 resimden 1. Samsung Chromebook Pro Hinge Replacement: adım 11, 3 resimden 2. Samsung Chromebook Pro Hinge Replacement: adım 11, 3 resimden 3.
    • Lift the hinge to remove from the Samsung Chromebook Pro.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Amber Castro-Beltran
933 İtibar
5 adet Kılavuz yazıldı
Ekip
6Kılavuz Yorumları
Great guide! One question: where can I buy the actual replacement hinge? Any tips?
Guy - Yanıt Paylaş
I was able to find the hinges for mine on the Global Direct Parts web site. The item name is: OEM Samsung Chromebook Plus XE513C24, Pro XE510C24 Metal Hinge Set
Rob Riggle - Yanıt Paylaş
How did you remove/unloop the cables in the hinges? do they just come right off?
Darby - Yanıt Paylaş
The cables are just pushed into the side of the hinge. One side had a stopper holding the cable in place that I had to pull out, but the other had nothing holding the cable (that was the broken hinge on my chromebook, so maybe it had a stopper that had fallen out at one point). Once the stopper was removed from the one hinge, I could pull the cables out, and push them into new hinges.
Andrew Cullum - Yanıt Paylaş
Just replaced these hinges on my computer … was only a bit confused with the stopper in the hinge but otherwise this guide was extremely helpful. Took about 30 min to do …
christophermdiaz - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 53
Her zaman: 9,551
