Ana içeriğe geç
Samsung Chromebook Series 3 Charging Port Replacement
Neye ihtiyacın var
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: adım 1, 3 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: adım 1, 3 resimden 2. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: adım 2, 3 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement: adım 2, 3 resimden 2. Samsung Chromebook Series 3 Charging Port Replacement: adım 2, 3 resimden 3.
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: adım 3, 3 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement: adım 3, 3 resimden 2. Samsung Chromebook Series 3 Charging Port Replacement: adım 3, 3 resimden 3.
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: adım 4, 3 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement: adım 4, 3 resimden 2. Samsung Chromebook Series 3 Charging Port Replacement: adım 4, 3 resimden 3.
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: adım 5, 3 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: adım 5, 3 resimden 2. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: adım 5, 3 resimden 3.
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: adım 6, 2 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement: adım 6, 2 resimden 2.
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: adım 7, 3 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement: adım 7, 3 resimden 2. Samsung Chromebook Series 3 Charging Port Replacement: adım 7, 3 resimden 3.
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: adım 8, 2 resimden 1. Samsung Chromebook Series 3 Charging Port Replacement: adım 8, 2 resimden 2.
    • You can now pull out the charging port module.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Andrey Radchishin
1.833 İtibar
4 adet Kılavuz yazıldı
Ekip
UWT Liner: Group 1 UWT Liner: Group 1 üyesi
Community
5 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - Yanıt
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 61
Her zaman: 17,389
