Ana içeriğe geç
Samsung Chromebook Series 3 Front Camera Replacement
Neye ihtiyacın var
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: adım 1, 3 resimden 1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: adım 1, 3 resimden 2. Samsung Chromebook Series 3 Front Camera Replacement, Screen: adım 1, 3 resimden 3.
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: adım 2, 3 resimden 1. Samsung Chromebook Series 3 Front Camera Replacement: adım 2, 3 resimden 2. Samsung Chromebook Series 3 Front Camera Replacement: adım 2, 3 resimden 3.
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: adım 3, 3 resimden 1. Samsung Chromebook Series 3 Front Camera Replacement: adım 3, 3 resimden 2. Samsung Chromebook Series 3 Front Camera Replacement: adım 3, 3 resimden 3.
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: adım 4, 1 resimden 1.
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: adım 5, 3 resimden 1. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: adım 5, 3 resimden 2. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: adım 5, 3 resimden 3.
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: adım 6, 2 resimden 1. Samsung Chromebook Series 3 Front Camera Replacement: adım 6, 2 resimden 2.
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
Sonuç
Tyler Schultz
555 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Henning Spring 2019 IUPUI, Team S2-G1, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S2G1
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 419
