Ana içeriğe geç
Samsung Chromebook Series 3 Speaker Replacement
Neye ihtiyacın var
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: adım 1, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: adım 1, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: adım 1, 3 resimden 3.
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: adım 2, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 2, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: adım 3, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 3, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement: adım 3, 3 resimden 3.
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: adım 4, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 4, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement: adım 4, 3 resimden 3.
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: adım 5, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement, Battery: adım 5, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement, Battery: adım 5, 3 resimden 3.
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: adım 6, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 6, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement: adım 6, 3 resimden 3.
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: adım 7, 2 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 7, 2 resimden 2.
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: adım 8, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement, Speaker: adım 8, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement, Speaker: adım 8, 3 resimden 3.
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: adım 9, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 9, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement: adım 9, 3 resimden 3.
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: adım 10, 2 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 10, 2 resimden 2.
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: adım 11, 3 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 11, 3 resimden 2. Samsung Chromebook Series 3 Speaker Replacement: adım 11, 3 resimden 3.
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: adım 12, 2 resimden 1. Samsung Chromebook Series 3 Speaker Replacement: adım 12, 2 resimden 2.
    • Pull the speakers up to remove them.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Andrey Radchishin
1.833 İtibar
4 adet Kılavuz yazıldı
Ekip
UWT Liner: Group 1 UWT Liner: Group 1 üyesi
Community
5 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Many thanks.
Excellent guide .
Triumph Trident - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,576
