Giriş
After a period of time, the device might run too hot, this guide will help to clean up or replace the cooling fan for the Samsung Chromebook XE550C22.
Neye ihtiyacın var
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Locate the cooling fan and the heat sink on the top center of the Chromebook.
Bu adımda kullanılan alet:Tweezers$3.99
Rotate the Chromebook 180 degrees so the fan is closest to you, and locate the fan power cable.
Disconnect the fan cable from the motherboard with the angled tweezers.
Bir başkası bu kılavuzu tamamladı.
