Ana içeriğe geç
Samsung Chromebook XE550C22 RAM Replacement
Neye ihtiyacın var
  1. Samsung Chromebook XE550C22 RAM Replacement, Back Panel: adım 1, 3 resimden 1. Samsung Chromebook XE550C22 RAM Replacement, Back Panel: adım 1, 3 resimden 2. Samsung Chromebook XE550C22 RAM Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 RAM Replacement: adım 2, 2 resimden 1. Samsung Chromebook XE550C22 RAM Replacement: adım 2, 2 resimden 2.
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 RAM Replacement: adım 3, 3 resimden 1. Samsung Chromebook XE550C22 RAM Replacement: adım 3, 3 resimden 2. Samsung Chromebook XE550C22 RAM Replacement: adım 3, 3 resimden 3.
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 RAM Replacement: adım 4, 2 resimden 1. Samsung Chromebook XE550C22 RAM Replacement: adım 4, 2 resimden 2.
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 RAM Replacement, Battery: adım 5, 2 resimden 1. Samsung Chromebook XE550C22 RAM Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 RAM Replacement: adım 6, 2 resimden 1. Samsung Chromebook XE550C22 RAM Replacement: adım 6, 2 resimden 2.
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 RAM Replacement, RAM: adım 7, 1 resimden 1.
    • Locate the RAM on the middle right side of the Chromebook.
  8. Samsung Chromebook XE550C22 RAM Replacement: adım 8, 2 resimden 1. Samsung Chromebook XE550C22 RAM Replacement: adım 8, 2 resimden 2.
    • Using your fingers, separate the silver clips that are holding the RAM in place on each side.
    • The RAM will "pop-up" on its own after separating clips.
  9. Samsung Chromebook XE550C22 RAM Replacement: adım 9, 2 resimden 1. Samsung Chromebook XE550C22 RAM Replacement: adım 9, 2 resimden 2.
    • Pull the RAM away from the Chromebook.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Abel Osorio
330 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G7
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 688
